Results 1 to 5 of 5
Thread: Celica diff with factory LSD
    Travis
    qld
    Ipswich
    Hey guys. I have done an ra40 celica diff conversion. I have used the entire diff housing and everything. Will a second hand JDM center fit in without cutting axles? Was just not sure as some say the they are wider and then they aren't... some put celica axles into JDM housings, some say they hit.... I'm all confused... JDM diff center into RA40 diff housing....
    Please help! Travis
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    <div class='quotetop'>QUOTE (Insane @ May 27 2008, 06:13 PM) </div>
    The JDM centre will only fit if it is the early model (zenki) one. I am 99% sure that when you fit a LSD into a non LSD housing you have to cut the axles down by about 10mm each. Just cut the ends off them with a grinder should be fine then file the sharp edges down so the splines resemble what they were originally.
    Ferny Grove
    a zenki (early) centre will bolt in fine
    you only cut down RA axles when you use them in the narrower T18 or zenki JDM AE86 T series diffs
    you shall have no need to cut axles just swap the centres
    Travis
    qld
    Ipswich
    Thanks Gilly. I Thought that might be the case. So the Ra 40 dif's really are wider...
    Jonathan
    If you use a factory Toyota LSD, from a early AE86 or TE71, and you are putting this in a complete RA40 rear end, you may have to grind the axles 5mm shorter.
    I say this because I know you do have to do this with a AE86 when you use a Toyota LSD in a car that wasn't originaly LSD. (The factory LSD axles are shorter).
    But if you are using a TRD brand LSD, you will not have to cut the axles.
    Since TRD or aftermarket LSDs are more common than factory Toyota LSDs amoung second hand gear in Australia, we don't see this problem very often.
  1. zenki factory lsd center wanted
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 15th March 2012, 10:33 PM
  2. GT celica F series disc brake rear end with KaaZ LSD
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 12th May 2011, 12:33 PM
  3. WTB Zenki factory LSD centre in any condition
    By Golberg in forum Cars or Parts Wanted
    Last Post: 14th September 2010, 09:08 PM
  4. Weight of the factory ae86 Diff?
    By Craved in forum Technical - Questions
    Last Post: 21st June 2010, 10:49 PM
  5. oem factory lsd
    By .ady in forum Technical - Questions
    Last Post: 1st September 2009, 08:23 PM
