Page 11 of 14 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 101 to 110 of 140
Thread: Converting a 3sge to RWD
  1. #101
    Veteran biggo's Avatar
    Nick
    Noosa
    Less discussing and more 3sge converting. I did this today cos i only have one arm and cant weld for another few weeks.
    started with a Hilux Y motor water outlet
    Modified it
    Finished for now
    Im going to be running a slimjim oil pressure sender so dont stess. ACIS or whatever that hole in the middle of the cam covers needs to be blocked off in my case, im using quads so whatever it does i dont want.
    I need to fit a water bypass fitting in the water outlet but ill do that another time.
  2. #102
    Glenn
    North Ringwood
    Default gen 2 3sge
    ok some front pics on my 3sge this was my gen 2 with water outlet at the front
  3. #103
    Glenn
    North Ringwood
    and the oil drain backs as my motor was set up like the std 1 with a 20mm out of level like a 18rg motor
  4. #104
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    That is exactly how MiCs was done
  5. #105
    Glenn
    North Ringwood
    mics was copied from my motor
  6. #106
    Nick
    Noosa
    Motor as it is, had to extend the clutch slave pushrod 15/20mm for some reason.
    2sc starter, stock headers, sa63 bellhousing, its a bit tight
  7. #107
    Moderator Sam-Q's Avatar
    Endeavour Hills
    try the starter of the ae92 twinky, it has the same mounts but has the motor directly above instead
  8. #108
    Veteran driftke70's Avatar
    Ryan
    Buderim
    wheelfriends.wordpress.com
  9. #109
    Veteran slydar's Avatar
    Dimitri
    a 4age starter will definitely not fit/work with that bell/ring gear.
    p.s lol medwins idea of how lubrication works.
    78's
  10. #110
    Senior Member tin can's Avatar
    Jess
    hi all
    can i fit a beams (sxe10) oil pump and sump to a gen2?
  1. RWD 3sge corolla $2800 ONO PICS
    By gottago in forum Cars for Sale (Toyota Only)
    Last Post: 7th May 2010, 01:10 PM
  2. tarago diff and rwd 3sge stuff
    By old_school_jap1 in forum Car Parts For Sale
    Last Post: 22nd February 2010, 10:16 AM
  3. Gen3 3sge RWD corolla in SYDNEY
    Last Post: 25th October 2009, 11:06 AM
  4. rwd 3sge. What dizzy???
    Last Post: 12th April 2009, 11:24 AM
  5. 3SGE RWD parts
    By 20valve69corona in forum Car Parts For Sale
    Last Post: 10th April 2009, 10:24 AM
