Page 12 of 14 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 111 to 120 of 140
Thread: Converting a 3sge to RWD
  1. #111
    Andrew
    Yes, will relocate the oil filter in the bargain.
    You can fit the sump and pump together, but no one or the other alone. The beams sump has the pressure relief in it and the pump will just pump straight back into the sump if you don't use the beams sump.
    I went the other way, converted my gen3 gte (same setup as beams) to
    5sfe pump and 2s (modified) sump.
  2. #112
    Anthony
    just make sure its an SXE10 or ST215 pump so it has the crank trigger divet to match the sump. normal gen 3 pump wont line up.
  3. #113
    Glenn
    North Ringwood
    ok oil returns on the gen 2 motor side and back
ID:	4882   Click image for larger version.
  4. #114
    Hey Biggo i dont know whether your interested but im selling some Quads on a custom manifold to suit 3SGE Gen 2
    Just thought you might be interested
  5. #115
    Senior Member tin can's Avatar
    Jess
    whats the depth on a beams sump.
    e.g from the bottom of the block to the bottom of the sump.
    just want to see the diff from a 2s to a 3s beams
  6. #116
    User fantapants's Avatar
    Pat
    16 cm give or take... its cold and dark
    06/07/2011
  7. #117
    Moderator Sam-Q's Avatar
    Endeavour Hills
    can someone tell me what this flange in the sump casting does on the half cut-off left hand side of this pic?
  8. #118
    Endeavour Hills
    never mind the post above, I found an old post that explains this is for the spring that controls the pressure releif of the oil pump, ie: dont mess with it
  9. #119
    Anthony
    phew, i was having deja vu!
  10. #120
    Jonathan
    I work on a KE25/3S-GE car and currently have it all in bits again. It was running fine.
    It has a SW20 motor. SA63 belhousing and everything I think. The holes in the flywheel have been filed oval. A double row bearing was used in the crank. But there was limited movement for the clutch fork, and the owner filed out the hole in the belhousing a bit. Clutch was slipping a bit, not sure why.
    Not it's apart, we are going to try a normal spigot bearing, and are having the belhousing milled 6mm off the engine/belhousing surface. Im told another way to do this is just extend the clutch pivot about 6mm, which would be easier.
    Water system works but is a mess, so any more neat rear water pictures would be great.
  1. RWD 3sge corolla $2800 ONO PICS
    By gottago in forum Cars for Sale (Toyota Only)
    Last Post: 7th May 2010, 01:10 PM
  2. tarago diff and rwd 3sge stuff
    By old_school_jap1 in forum Car Parts For Sale
    Last Post: 22nd February 2010, 10:16 AM
  3. Gen3 3sge RWD corolla in SYDNEY
    Last Post: 25th October 2009, 11:06 AM
  4. rwd 3sge. What dizzy???
    Last Post: 12th April 2009, 11:24 AM
  5. 3SGE RWD parts
    By 20valve69corona in forum Car Parts For Sale
    Last Post: 10th April 2009, 10:24 AM
