pretty sure the wade's are re grind.. youll need to supply some old cams, and have them re ground. same for crow. they might be able to source some for you, or do new billets, but it will make the pricing difference from these locally made ones to new japanese ones seem inconsequential.
alot of engine builders will tell you spend as much as you can on cams, it will make the difference. having said that, even the smallest offerings from even the local companys will make a noticeable difference you will appreciate.
but to answer your questions, best just to call them, and ask how their offerings compare to cams from japanese manufacturers with an "advertised" duration of 256 or 264 with 8mm lift, which is what you wanna stick around with stock management.
