Results 1 to 7 of 7
Thread: AE71 Auto lock out
    May 2008
    Hello all,
    I'm in the process of changing the 4ac auto to a 4age manual. The info I'm after is the neutual lockout on the auto. Does anyone know what colours are the wires are in the loom?? For the life of me I can't work it out. The worst part, thats all that is stopping me from starting it............. today.
    Cheers in advance,
    Regards,
    Jake
    Oldschool Member
    Mar 2008
    hey mate,
    PM Slide86 on the forum...he has recently overcome this problem and he will be able to help you out..
    May 2008
    Cheers will do.
    May 2008
    Anyone??
    Ferny Grove
    2 pin plug, drivers side, on the trans tunnel just before the seat
    should have a black and white wire on at least one plug. unplug it from the shifter and bridge the plug (pretty sure its the female plug) either way you are bridging the connector (join the 2 terminals together with connectors and wire) on the side of the loom that goes back towards the front of the car not the shifter!!
    i had the same issue with a KE of mine. had start signal from the switch but never made it to the engine bay, i forgot it was auto originally!! short section of wire, 2 male spade terminals and it was all sorted.
    May 2008
    Hey Gilly,
    Thankyou for that, but the bloody AE and KE must be different!!!!!!! The plug on the AE near the trans tunnel is only the lights for the shifter. Thankyou anyway!!!
    Anyone know where I can get an AE wiring diagram??
    Cheers All,
    Jake
    Ferny Grove
    hmmm there really should be something i nthat region for the neutral start switch.
    if you have a digi camera get me a pic of your shifter (obviously with all plastics removed) and any wiring and plugs in that area.
    there will definitely be something there
  1. SA: AE71 auto defected
    By JinxD in forum Cars for Sale (Toyota Only)
    Last Post: 5th May 2012, 04:31 PM
  2. Wrecking AE71 Auto - NSW
    By Golberg in forum Car Parts For Sale
    Last Post: 13th February 2011, 08:30 AM
  3. ae71 auto diff
    By shakes in forum Cars or Parts Wanted
    Last Post: 7th September 2009, 03:53 PM
  4. ae71 auto parts?
    By trikzlane in forum Technical - Questions
    Last Post: 15th August 2009, 12:10 PM
  5. AE71 Auto to Manual Conversion
    By Jonezee in forum Technical - Questions
    Last Post: 10th April 2008, 11:32 AM
