Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Compression Test
  1. #21
    it also depends on the guage you are using aswell.
    usually you should not really on the actual figure it gives you but as a guide to determine each cylinder in relation to other cylinders. i.e picking out lazy/low cylinders
    i have used different guages from old to new and different brands and they will all read differently. 210 on one guage could be 180 on another etc. i have even had 2 of the same brand guages on the same engine read differently
  2. #22
    zilla
    nsw
    central coast
    <div class='quotetop'>QUOTE (Mech`s Blue @ Jun 15 2008, 02:01 AM) </div>
    Fair call.
    My stock bigport (220k km, never rebuilt) gave 145-150psi across all four under a dry comp test, with my cheapo supercheap gauge. It still packs a reasonable punch, but blows a little smoke under load, so rebuild time is coming. Dyno'd at 99hp@wheels with quads & aftermarket ecu.
    I recall the manual stating 135-140psi is rebuild time.
  3. #23
    B
    nsw
    glenwood
    aus
    It sounds about right to me,
    my stock 100KW bottom end, with new pistons, and rings, 0.5 TRD Head Gasket, 270 ish cams, and quads,
    comes in at 260 PSI across all four on the last cold test i did.
    but we are putting out 95KW atw now.
    Ben.
  1. AE101 4agze Compression test results
    By trikzlane in forum Technical - Questions
    Last Post: 13th May 2011, 11:58 AM
  2. Blacktop Compression Test Results
    By Matt in forum Technical - Questions
    Last Post: 4th August 2010, 02:44 PM
  3. Bench Compression Test
    By Gilly in forum Technical - Articles
    Last Post: 9th May 2008, 04:11 PM
  4. no compression
    By kaneO in forum Technical - Questions
    Last Post: 27th November 2007, 10:34 AM
  5. compression test
    By albertos in forum Technical - Questions
    Last Post: 17th June 2007, 11:19 PM
