I had a Earls brand sandwich plate on my block just as a test fit, and once I had 2 AN-10 fittings screwed into it there was only a few positions it would go in, and a feared one the oil hoses were screwed on they would not fit, or rub on the oil pressure switch. Anyone got a pic or a brand of sandwich plate that fits good, with oil filter in stock position?
I have the factory oil cooler thing I may use (low pressure, draining back to sump, fits well) but the only concern is that it would cause a pressure drop, and this will be a high reving motor.
