hey guy's
i recently replaced some wheel bearings and rear brake shoe but found that one of the little slave cylinders i think its called ( in the rear drum that pushes the shoes apart) had sezied up, i got brand newies to replace them but ever since i have had a really weird feel on the brake, driving around normal the brake is kinda spongey and will go down to the floor but when the revs are high, ie going down a hill in 3rd or whatever, if i push on the brake, release and push down again the brake pedal will get harder and harder, then it will go soft again. can anyone tell me what this could be? air in the lines? brake master given up the ghost? any help would be great.
cheers bart
ps. i did bleed the system with one of those bottle looking things that the mechanics have that use air pressure whatever it is and also bleed manually with a mate
