i put to bars across the stock rails and then bolted it to that, works well and it still goes forward n back
just wanna see some pics of how people have mounted there aftermarket seats. custom rails, etc, how low did you get it
Cheers in advance
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
<div class='quotetop'>QUOTE (SON57A @ Jun 12 2008, 12:56 PM) </div>Pics? :blink:
bride super low seat rail![]()
-=Back by popular demand=-
<div class='quotetop'>QUOTE (marvis @ Jun 12 2008, 12:58 PM) </div>ill see if i have one, if not next time I'm at my place ill take one
...just looked i have none, when i go back to my place ill take one for you
i did the same as sonsta. if ur seat is bottom mount its really easy. i boguht 4mm steel to lay across my stock rails, measured the distance between the front and back bolts under the seat and welded the steel into place. then i just drilled out where the holes would go through the steel from the seat (twice cuz i can't measure too good) which took ages cuz i used so thick steel. i used a 2mm, 5mm, 8mm and 10mm bits and alot of drill coolant stuff. it really is easy just pull ur stock rails off ur seat and you'l know what to do from there
Dad and I welded a bit of 6mm flat bar to the original seat rail. Drilled holes in the flat bar for the seat to bolt on to.
yeh i used some tube steel stuff cos i wanted to sit higher...I'm a short bugger
heres some pics (note quality welding skillzzz)
<div class='quotetop'>QUOTE (SON57A @ Jun 12 2008, 02:20 PM) </div>
son57a that is exactly what I'm looking for, can you do us a favor, i need to also see the clearence from the steering wheel to the seat.
can you move your seat forward or back at all, looks fixed in that position to me, i wanted to make up some sidemounts for adjustability
btw, my seat is bottom mount, 20v kid, does the seat flex at all during turns????, cos ive noticed compared to son57a's rails, you don't have any support across the seat base
SQ ENGINEERING
NCCE
i can move it back and forwards yes.
i will measure and take a photo of clearnace for you, my legs don't hit the steering wheel at all as they sit either side of it, theres probably 125mm clearance or somethin
