Unless it's a hardcore track car, you're an engineer and you're really motivated to, then it really isn't worth it.
Watts links are only better because the diff does not move towards one side of the car when the suspension is under compression.
5 Link rear ends are flawed that way. the panhard bar causes the the diff to travel through an arc as it goes up and down. Watts link rear ends eliminate this.
