Results 1 to 4 of 4
Thread: 20v ecu
    Oldschool Member
    Mar 2008
    hey guys,
    i have a 20v silvertop and i wanted to run a blacktop ecu. the problem is that i can only find auto trans ecu's and was wondering if and how to run this with a manual g/box? also are there any problems associated with doing this?
    Cheers,
    ShaunLovell
    gunbz-r
    There is no real issue to be caused from running an A/T comp in a manual car. Some people have also noticed a higher RPM cut, i don't know how consistent that is.
    Rhys
    Oldschool Member
    Mar 2008
    so i just pretty much wire it up according to the auto trans diagram yeah??? there arent any tricks that i need to know about???
    gunbz-r
    I'm not 100% on how its done, i don't see it as enough of a gain, apart from, being able to run a map sensor instead of the flow meter, and that needs to be wired in place of the flow meter, which I'm unsure on how you'd do it.
  1. Replies: 6
    Last Post: 12th September 2012, 10:01 AM
  2. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  3. Replies: 0
    Last Post: 29th January 2012, 04:29 PM
  4. WTB: 20v wiring loom & 20v ecu
    By Bobomacho in forum Cars or Parts Wanted
    Last Post: 26th March 2007, 09:06 PM
