Results 1 to 10 of 16
Thread: alternator mounting
    Elite rthy's Avatar
    Leo
    Tulla
    I would like to hear what do people think is the best place for an alternator on various 4age engines? I like it on the intake side down low but I think what I have now is a little too low.
    I currently have this:
    which I think is definatley on the crap hole end of my so called fabrication ability. I am thinking of making a new mount up (and maybe a few extra for guys on here) that sits a little higher and is machined from a solid block of steel for no flex and perfect alignment. Same princible as now but just significantly better made with the mounts that the pivot bolt for the alternator shaped above the mounting points for the block mounting holes, so therfore this would also hold the alternator very close to the block and higher up.
    feedback welcome
    Veteran slide86's Avatar
    Huw
    Hills
    go the JGTC style and mount it under the car and run it off the tailshaft
    and that setup looks good for us GZE boys. id definetly be keen on a Q designed bracket
    gunbz-r
    I prefer intake side, I don't like the idea of that much heat near electrical components.
    Where you have fitted isn't too bad Sam, though you could easily fit it that low on the intake side, and leave room for cooling outlets & etc. If it sat below the sump flange i'd say its too low, but it above it so you do have a good 6-8 inches from the bottom of the sump. If your worried of stones or road debree make a shroud or somethin.
    Though I don't agree with the adjusting bracket being mounted to an exhaust flange bolt.
    Rhys
    Elite rthy's Avatar
    Leo
    Tulla
    slide 86: yeah I figured that everyone with a GZE would be crying out for a common off the shelf alternator that is compatable. Its going to be a long while before I buy my mill and potentially jig it up to make some of these but if I do I really don't think it would cost much to make the bracket alone, I am looking at under $50 not including the tensioner.
    gunbz-r: I have thought about putting it low down on the intake side, for example look at this pic below thats a picture of the classic RWD 20v cooling system problem:
    it doesnt take a genious to figure out that putting a hole-saw through the alternator for the cooling hose isnt going to work so well. This is the reason why I moved my alternator in the first place. Now looking at that pic I have been thinking of something along the lines of what your talking about, how does this sound; I considered putting the alternator upside down so it just clears or rubs against the lower radiator pipe with a RWD pump. Obviously by pissing off that existing mount I would have a swinging pivot near the bottom. Beats me if I would have the room for it but I am going to check it out. I am always looking for ways to make things better laid out in my setups. heat is a good point but seeing the alternator is further foward and lower than my flange it shouldnt cop too much but you never know eh?
    With my current design apart from the crappy way I made it I don't mind the position. I know though its a little to low as it doesnt let the drive belt have enough of a wrap around the main pulley as what I would like, but this is why I would raise it a bit. Also with the tensioner while I will still use that design, the way I did it in the first pics was crude. If I was to make a few extra mounts ontop of remaking my own then the tensioer would still work on the princible of ditching the existing tensioners which I find to be bulky, heavy and pretty prone to seizing up with the old fasioned pull away and tighten type. The difference from last time being would be that I would keep the angled tensioner quite close to the alternator instead of having it come down on a 45 degree angle from the exhuast flange like now.
    Can anyone think of a better tensior option? I really hate the stock design. Another thing I started to make is a tensioner thar suited what I had now but had a long thread to pull the alternator so it ended up being like a hybrid between the 20v type design and what I run now. I think I will get back to that.
    Oldschool Member
    Mar 2008
    why not 16v RWD alternator bracket?
    Elite rthy's Avatar
    Leo
    Tulla
    its either hard to come by or its quite expensive.
    Ok I admit i don't know the exact design that well but I am guessing that the Trueno mount I would personally find I like my mount to be lighter, lower and closer to the block.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    This is the RWD alt bracket for your reference:
    I bought mine off ebay here in Australia, only paid $56 for it, brand new toyota genuine. I couldn't believe how little it went for I'm guessing people just didn't know what it was (this was like 2 months ago).
    And yes it'll solve all the worlds problems (well at least all of the RWD cooling alternator problems)
    Elite rthy's Avatar
    Leo
    Tulla
    ok thanks, I went looking for a good picture but I couldnt find anything. Looks pretty decent, any chance of a pic on the engine?
    Lawrence
    Wollongong
    Well this is all I've got on me right now:
    That was my first temporary water setup, its now got a different thermostat inlet and heater return pipe. It also now encompasses the throttle body water supply too. I'll try get some better pics for you tomorrow (its in the car now)
    Elite rthy's Avatar
    Leo
    Tulla
    looks really neat overall. So there isnt much of an issue in regard to fitting under the lower radiator pipe?
  1. WANTED AE86 Alternator mounting bracket please
    By 4AGE FORD in forum Cars or Parts Wanted
    Last Post: 15th December 2010, 08:31 AM
  2. mounting different seats?
    By w84me in forum Technical - Questions
    Last Post: 15th August 2007, 04:54 PM
  3. Harness Mounting
    By Touge205 in forum General Topics (No Technical Questions)
    Last Post: 7th January 2007, 06:10 PM
  4. Another 4agze alternator mounting thing :P
    By jason in forum Technical - Articles
    Last Post: 8th December 2006, 10:26 PM
