Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: 7ac
    [attachment=27379SC01421.JPG]Ive seen 4ac heads on 7afe 1.8lt blocks. I heard you don't need to mod anything for this conversion.
    Is the power good? is it worth it? do i need to find a new cambelt to suit?
    Veteran slide86's Avatar
    Huw
    Hills
    1. why is there an engine crane in your post
    2. better of just getting a 7afe and put a carby on it......if you really must.
    3. just get a 4age, it will be better
    Aaron
    In the Mountains
    agreed.
    yes a 4ac should fit on unless the 4afe has meaty pistons that stick out past the top of the block.
    would make a fairly toquey motor for a daily driven ae71, but other than that i wouldn't think it would be worth it.
    whats the power figure of a stock 7afe? well putting a 4ac head on it will decrease the power. you wont gain any compression either, 4ac and 7afe have near identical combustion chamber cc's
    Nat
    Newcastle
    If you want to keep it carby you could use a 7afe with the carb/manifold/distributor from a 4afc.
    With a 32/36 weber on it it would be a rather torquey motor. Also if you look up Billzilla's page on Google you will find some good info on getting decent hp out of the f series heads as well.
    Wish I had thought of it earlier, would have been an interesting conversion
    Veteran Konakid's Avatar
    Henry
    Eastern
    hahahah 4age86 and i were thinking about this a while back, would be way to much effort for minimal return.
    Aaron
    In the Mountains
    oh and your other question about the timing belt. you should be able to use a 7afe one because it only drives the one cam gear as does the 4ac but i don't know if the 7a block is slightly taller and would require a longer belt than a 4ac.
    Aaron
    Vic
    Ballarat
    <div class='quotetop'>QUOTE (ae71 @ Jun 23 2008, 11:50 AM) </div>Block is taller
    [attachment=27414SC01405.JPG]
    better yet 7age
    [attachment=27415SC01370.JPG]
    i heard porcshe cambelt fits? clarification.
    and will the stock ecu screw you over?
    gunbz-r
    that bottom pic is a rotary dude.
    riojin
    it is clearly a rotary in the 2nd pic.
    is this thread a joke? i seriously don't get it and if its a joke it makes that ok
  1. Replies: 8
    Last Post: 22nd August 2011, 12:31 PM
  2. VIC: White Manual AE71 CSX, 7AC, T series, 86 Struts, 12 months Rego.
    By Sprinter86 in forum Cars for Sale (Toyota Only)
    Last Post: 19th March 2011, 09:10 PM
