Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: 7ac
  1. #21
    Nat
    Newcastle
    Cam belt from memory is off a Porsche 944 - I'm pretty sure there is a write up on Club 4ag from memory.
    From memory the 7afe psitons, when used with a 4age head result in rather low compression.
    As for turboing the 7age I feel that kind of misses the point - the only logical reason for going 7age I can see (and it's the reason I am looking at it) is to remain in the under two litre class for hill climbs, etc. Turboing would move you into the over 2 litre class for my local climbs, in which case you may as well step up to a 3sgte.
    The same could be said for 7age vs 3sge I guess......
  2. #22
    gunbz-r
    there is a toyota belt that fits.
  3. #23
    no modding engine mounts or bellhousing makes 7age>3sgte thats it.
    I saw some conrods on trademe for about $500 i suppose it is necessary to change the conrods
  4. #24
    Trev
    Queensland
    Redbank Plains
    I will find out tomorrow what timing belt we are using on our race car.
    The main reason behind the 7A having a low rev limit is the fact that they have everything down low, There is no point on them being a high revving engine as standard as its not going to make anymore HP or torque.
  5. #25
    especially because they were made to suit auto boxes
  6. #26
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    I made a thread about 7AGE into ke/ae's. Doesn't go into too much detail it's just how to basically install it. It isn't finished yet as I havent got the engine in.
    Anyway, I plan on Arias forged pistons, some sort of forged con rod and maybe a 4agze crank, depending if it is the same.
  7. #27
    Senior Member 4door's Avatar
    Apr 2010
    South Australia
    Hills
    i guess a 7afc or something could be a good upgrade for people not able to afford a 4age or something
    1.8 block with 4afc head and stock carb set up.
  8. #28
    Trev
    Queensland
    Redbank Plains
    I forgot to get the belt details today, I will try to remember tomorrow.
  9. #29
    Senior Member shinny's Avatar
    Liam
    <div class='quotetop'>QUOTE (Trev084 @ Jun 25 2008, 07:33 PM) </div>
    if you had a better flowing head/intake manifold they would make more torque/kw into the higher rev range
    the reason they make most of their torque down low is because the intake manifold/head is designed for a everyday A-B car
    this is the way i understand it ^^
  1. Replies: 8
    Last Post: 22nd August 2011, 12:31 PM
  2. VIC: White Manual AE71 CSX, 7AC, T series, 86 Struts, 12 months Rego.
    By Sprinter86 in forum Cars for Sale (Toyota Only)
    Last Post: 19th March 2011, 09:10 PM
