Results 1 to 8 of 8
Thread: 4a rwd sandwhich plate
    Member richo's Avatar
    Matthew
    Capalaba
    ok guys
    I'm after a 4a sandwhich plate for the 20v
    if anyone has one let me know thanks
    the progression-
    HTML Code:
    http://www.ae86drivingclub.com.au/forums/showthread.php/16113-richo-s-86
    Rob
    Moorabbin
    you need an adm one?
    if so, can do
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    The starter is on the exact same side on either the JDM or ADM one, its only the clutch slave/fork etc which moves.
    Why do you need it on the opposite side anyway?
    Mar 2010
    yeah only advantage is to get clutch lines away from the heat
    i have adm bellhousing and jdm let me know what u want
    Matthew
    Capalaba
    ive got a 20v which has the starter on that side so when joining the gearbox and engine the housing doesnt fit. unless the starter can be moved easily but havnt found away.
    also i have a adm housing but bolt pattern isnt the same........
    maybe this should be moved to the tech q's...
    the progression-
    HTML Code:
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    adm and jdm bells have the same bolt patterns, thats why people can put jdm bells on adm boxs. Shaw you don't have a t18 bell and jdm one?
    MY JZX83 (clicky)
    Lawrence
    Wollongong
    I think I understand what you are saying, can't say I've actually seen a 20v in FWD form but I think what you really need is the RWD 4A sandwich plate, that will then line up the starter with the ADM bellhousing for you.
    Matthew
    Capalaba
    <div class='quotetop'>QUOTE (Golberg @ Jun 23 2008, 10:23 PM) </div>BINGO
    with further research into the matter, i didnt realise i had to change it over :confused:
    sorry bout the hassle and thanks to every one for the help
    so who has a rwd 4a sandwhich plate.......?
    the progression-
    HTML Code:
  1. w5x to 4a adaptor plate
    By _wanna-be_ in forum Technical - Questions
    Last Post: 17th July 2012, 05:51 AM
  2. AE86 Windscreen Trims and T3 4a adaptor plate
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 29th July 2011, 01:24 AM
  3. TVIS plate to suit bigport 4a
    By reecegze in forum Cars or Parts Wanted
    Last Post: 27th January 2010, 04:12 PM
  4. 4ac/t50 sandwhich plate
    By shakes in forum Cars or Parts Wanted
    Last Post: 2nd September 2009, 04:23 PM
  5. WTB: Oil Cooler/Filter Sandwhich plate
    By 4A-GE Power in forum Cars or Parts Wanted
    Last Post: 11th September 2007, 01:06 PM
