Results 1 to 5 of 5
Thread: Pedal box help!!!!
    Senior Member ke70 xx's Avatar
    Troy
    Woody
    Default Pedal box help!!!!
    After help with installing hydraulic pedal box in my ke. Going to be using t18 one and just bit worried about were to drill holes to mount slave cylinder and clutch master. Pictures havent really helped me and people have explained to me but dont understand it 100%. Wondering if anyone in Adelaide can give me a hand or has a template I can use. Really appreciated. Also if your not going to help and are just going to say stupid shit to pay me out then get a life cause you need one if your hacking into people who dont have alot of experience with these sorts of things. Cheers Troy.
    Quote Originally Posted by MINIHORSE View Post
    "if i ever get another 86 i think it will be a track only car"
    Tried that....failed.....you will too....its like sleeping next to a supermodel everynight and only getting to nail her 5 times a year
    Theres a thread in the technical articles section explaining this, I think its quite a good run through from memory.
    Veteran bigm's Avatar
    Gold Coast
    im pretty sure when i did mine there was provision for the MC.
    I bolted up the pedal box and looked to see where it would line up, and there was a raised section in the engine bay that matched the MC size. i Just drilled lots of little holes around the inside of the circle and then hit it out with a hammer, then cleaned it out with a dremmel.
    THis was for a ae71 box, im assuming the t18 box uses the same position for the MC.
    so just have a look for the rasied section on the firewall.
    hope this helps.
    Senior Member Simon-KE70's Avatar
    S
    if you want, when i come round i can mark the fire wall in the correct spots for you to drill out from there?
    Troy
    Woody
    Would be great. Thanks for that. Wrote it in my pm reply to you.
  1. Replies: 3
    Last Post: 27th November 2011, 06:35 PM
  2. Pedal box
    By Devans in forum Technical - Questions
    Last Post: 23rd June 2011, 07:58 PM
  3. ae86 pedal box
    By keimeier in forum Technical - Questions
    Last Post: 24th March 2010, 10:59 PM
  4. 4A manual gear: JDM box and manual pedal box.
    By resol in forum Car Parts For Sale
    Last Post: 14th March 2010, 11:28 PM
  5. T18 Pedal Box insted of AE71 Pedal Box????
    By ke70 xx in forum Technical - Questions
    Last Post: 8th May 2009, 04:08 PM
