Results 1 to 10 of 19
Thread: st/bt quads
    Stefan
    Parkinson
    how do you tell the difference?
    i knw the holes on the black top are different
    and what are the 2 bore side measuremnts?
    Oldschool Member
    Mar 2008
    While both engines have round throttle blade size the blacktop thottle blades are larger at 45mm compared to the 42mm of the silvertop. The casting of the throttle housing is also different as unlike the silvertops round openings the blacktop has more of a heart shape to suit the different manifold (see "Inlet manifold"). The throttle bodies are not readily interchangable as they have different port shapes on the exit and although they would bolt on the airflow would become quite turbulent. The mounting points are also wider apart for the trumpets on the blacktop engine
    Stefan
    Parkinson
    cheers chris
    Elite rthy's Avatar
    Leo
    Tulla
    here you go an article I wrote:
    Oldschool Member
    Mar 2008
    ^^^its where i grabbed the info from.....
    somehow i think people don't bother using search or looking in the faq.....
    Elite rthy's Avatar
    Leo
    Tulla
    you know I really should of read your post a little better!
    anyway I think many people simply do not know whats in the FAQ section.
    Ferny Grove
    heres one for you Sam
    what is the measurement of the inlet to the throttle bodies on both ST and BT?
    as in i guess the IDA of the inlet trumpet mounting flange
    EDIT: its not a test i am genuinely interested to know this measurement
    Elite rthy's Avatar
    Leo
    Tulla
    the answer for that will take untill friday, if I remember I will have it by then
    Ferny Grove
    haha you're a good egg
    you use your powers of parts access and i'll use my power of internets and see who wins
    Ok
    Seamus
    Milton
    Blacktop: 49.35mm according to my measurements just done then
    ^ Clicky clicky!
  1. WTB: 20v bt/st engine and t50 gearbox
    By ballos in forum Cars or Parts Wanted
    Last Post: 16th May 2011, 11:41 PM
  2. ST or BT 20v for 7AGTE Build? Keep vvt?
    By PRIMRK in forum Technical - Questions
    Last Post: 13th September 2010, 07:03 PM
  3. Is there a difference between bt and st 20v head???
    By slider4life in forum Technical - Questions
    Last Post: 12th July 2010, 07:50 AM
  4. BT & ST wiring diagram?
    By HACHI - 6X in forum Technical - Questions
    Last Post: 3rd March 2009, 12:10 AM
  5. Are ST and BT dizzy's interchangeable?
    By Vezza in forum Technical - Questions
    Last Post: 29th June 2007, 11:36 AM
