Results 1 to 10 of 47
Thread: AE86 + S14 Crossmember + SR20?
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    I've heard someone say that people have used a S14 Crossmember (bolt in). So the sr20 drops straight in. i don't know where it sits hi/low back or forward. and i guess tunnel massage or mod with custom gearbox crossmember also don't know sr20 box or sr/rb hybrid box.
    Veteran DRFTPG's Avatar
    ADAM
    i highly doubt an s14 crossmember would bolt straight up. kaizen garage sells cross members to suit but.
    Veteran johl's Avatar
    Johl
    maybe they cut the middle section of an 86 cross member out and weld the s14 in so the mounts are there
    ADAM
    yeh if your good with a welder then cut the mounts off a s14 crossmember and weld them onto an ae86 one. or what i would do is cut a ke70 one up and sell your ae86 one, would bemuch more cost effective
    Aaron
    In the Mountains
    my cousin told me that a full R34 GTR BR26dett and AWD bolts directly into a trueno?
    jokes
    Johl
    ^^^^ only if ur not running lca's and bottom passenger side trailing arm
    Nov 2006
    THe SR crossmember is to wide to fit between the rails.
    Veteran Dom86's Avatar
    Dom
    Balga
    <div class='quotetop'>QUOTE (ae71 @ Jun 27 2008, 11:41 AM) </div>
    <div class='quotetop'>QUOTE (johl @ Jun 27 2008, 12:04 PM) </div>you need to have NEONS also!
    The Track Car Build: Indigo
    A Heap Of For Sale: The Heap
    Senior Member quadeyquade's Avatar
    Quade
    you need chrome rims bigger than the car too, otherwise it wont do sik skidz
    "New evidence found: Hoon driver linked to 9/11."
    Jun 2005
    it fits, you just need to drill out the holes in the crossmember
  1. VIC: ae86 and s14 parts plug and play sr20 ecu bride dmax
    By BMXB in forum Car Parts For Sale
    Last Post: 31st March 2013, 10:50 AM
  2. Setup ae86 with sr20 or s13 with sr20
    By MR 86 in forum Technical - Questions
    Last Post: 5th July 2010, 11:56 AM
  3. FS: Sr20 s14/s15 aftermarket inlet manifold Sydney NSW
    By ghetto ke in forum Car Parts For Sale
    Last Post: 1st July 2010, 08:51 PM
  4. Replies: 8
    Last Post: 29th April 2010, 02:10 PM
  5. Replies: 3
    Last Post: 9th March 2009, 07:18 PM
