i bought some adm standered front brakes to put on my car to pass blue slip with but they wouldn't fit over the axles/stubaxles(whatever there called)
now the front suspension has a coil over kit on it bu other then that ive got no idea what i actually need
do i need to but standered adm front struts (do they included the axle)
or can the lil axle be taken out and replaced with a smaler diameter one???
ok well heres a photo of some struts similar to mine... the part where the arrow is pointing (the stub axle) is to thick for the brakes i bought (standered adm ones) to fit over.
at the moment it has supra front brakes on it so I'm assuming the stub axle has been changed to a thicker one so the supra brakes fit flushly on it yeah???
so it would be right in saying i need to buy some standered adm struts for the brakes ive bought to fit over???
or can i jsut change the stub axle too a thinner one somehow??
<div class='quotetop'>QUOTE (#109 @ Jun 28 2008, 06:36 PM) </div>Yes, you can't go swapping stub axles, not without some fabrication fun.
Either that or just grab some stock AE71/KE70 struts (because they are a fair bit cheaper), arms and brakes and put them on you AE86 I doubt they are going to know the difference. Then just put the supra ones back on after blue slip.
