Results 1 to 9 of 9
Thread: Engine Conv- Advice/ recomendations?
    Dec 2009
    Have had my 86 for about a year now and have just under $ 5000 to spend on getting a engine conversion complete. Fully done and tuned etc. Considering the 20v black but still unsure.
    Any recomendations as to what engine would be the go ? would like it to run quite hard but can't drive turbo atm.
    Also where are some places in sydney ,or within a shortish drive
    Dave
    loootts of variables!!!!
    define "fully done"
    are you talking $5000 worth of parts, and you doing all the labor in your garage?
    if so then you can build a nice 20V no probs (within reason, cams + aftermarket ecu i reckon)
    but if your going to pay someone to do it, then you are going to struggle to get a stocko big port for that much "fully done".
    - Blaise Pascal
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    LS1 is a sick engine for an AE86. the engine conversion is never done either so it will be different
    FTP.
    Senior Member quadeyquade's Avatar
    Quade
    4ac
    "New evidence found: Hoon driver linked to 9/11."
    Elite rthy's Avatar
    Leo
    Tulla
    what 5k for a stock bigport fully done for 5k !?@!@
    Veteran driftke70's Avatar
    Ryan
    Buderim
    just use bp ultimate
    wheelfriends.wordpress.com
    Clinton
    Tweed Heads
    Bp ultimate with some octaine booster and Nos and some moth balls would like you about 10 years with 5k
    FTP.
    Veteran slydar's Avatar
    Dimitri
    under 5 isnt quite enough to do a drive in drive out 20v silver. BT's are quite alot rarer, if you find one at a good price, you might come close-ish to doing it for around 5 with stock management.
    get yourself a jdm ae86 and do it yourself, and youll have money left of for some suspension ect.
    if you swap the dash loom and engine loom (body) youll only need to run 1 wire for the fuel pump, and sort out a fuel system. everything else is bolt in save for the exhaust, which any exhaust shop can do.
    if you get a good one, later you can do cams and it will come close to matching an ST and sound better.
    78's
    Mar 2010
    buy my 20v complete set up and $500 would get the lot fitted. so $5500 on the road trd gear set cams cam gears and black top.
  1. Replies: 68
    Last Post: 19th August 2013, 01:31 AM
  2. New member. first AE-86, engine advice please.
    By aslsmm in forum AE86 Owners Forums
    Last Post: 26th May 2011, 06:51 PM
  3. Engine reconditioning, costs recomendations?
    By JinxD in forum Adelaide & SA Events and Discussion
    Last Post: 25th July 2009, 05:25 PM
  4. engine conversions advice?
    By razel in forum General Topics (No Technical Questions)
    Last Post: 19th August 2007, 07:53 PM
  5. weird engine noise! advice opinions please.
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 10:20 PM
