yes
however some Panel vans have an s series type centre
hey all
just wondering if a KE70 sedan diff centre will fit in the KE70 wagon housing?
are the sedan axles the same as wagon ones????????????
just thought id make sure
yes
as long as you also change over the crown wheel....
<div class='quotetop'>QUOTE (truenosedan @ Jun 29 2008, 07:19 PM) </div>Interesting, I'm guessing it'd probably be the AE71 variety seeing as they also run AE86 front struts? Then you'd basically have a complete ADM sprinter drive line and suspension (apart from the fact that PVs use leaf springs).
all KE and AE sedans and wagons have the same diff centres, and axles. panel vans have s series, and ae86 struts (although i've never seen a van with these struts...so?)
gunner:
ALL DRIFT MODIFICATIONSYou're a fucking idiot, and I am ashamed that you are part of this community. Sure there isn't many tracks, but praticing on the street isn't the alternative.
thanks for the info guys
