is the sandwich thermostatic? if yes dibs! Also the hoses and fittings where was the cooler going to be mounted? just to give me an idea of length etc.
Cerby
- Volvo calipers and vented rotors, good condition plenty of meat left on the rotor, comes with adaptor plate and bigger brake master cylinder and brakelines to suit, stops like a bullet train. 350
easy plug and play conversion.
- jdm bigport headers off a japspec ae86. manifold is in good condition, i took them off because i put on toda headers with 20v flanges. comes with heatshield if i can find it. easy 100 bucks
- cabin interior light good condition
- cheviot tri spoke advan oni style rims 14x7 0 offset, perfect size no rash or buckles, they were josh youngs spare pairs. 70 bucks
- 4 14" 185/60R14 tyres good for your thrashing plenty of tread left to burn. comes with rims
- nardi long boss kit 100mm good condition 50 bucks
- earls oil sandwhich plate for oil cooler setup comes with plate and threading. 30 bucks BRAND NEW
- braided lines to suit and 4 45deg fittings for smoother bends and oil cooler (cost me 40 dollars for fittings, 70 to braid the lines and 70 for the cooler) all brand new never used. 100 dollars
- dunlop slicks i picked up from anderson motorsports. plenty of meat left of it make an offer
-trd clutch pressure plate cover, with thicker flaps good to use over stock or get another clutch surface and off ya go. $90
located in rockdale area
all parts must go
Cerby
<div class='quotetop'>QUOTE (poh_86 @ Jun 30 2008, 09:44 AM) </div>PMd
are the brakes ready to bolt onto sprinter struts? or are they just pulled from the boat (volvo) that they came from?
oil cooler lines are just over a meter in length and one slightly longer to line up on the front grill
more than enough to adjust with the lines, also with the bends to fit u can line it sideways or i bought 90deg bends to line it straight.
earls sandwhich plate isnt thermostatic, however if ur good u can prob tap in a thread to the plate and wedge tap the head in. best getting a mechanic to help you with that
What size are the slicks?
