your 2 bolts in red are for the calliper to mount to the calliper bracket
the ones in green mount the calliper bracket and backing plate to the bottom of your strut.
the ones u have circled in green are put in the same way as the top picture
I'm not sure what u need to know
if u just want to take off your break assembly and put in on your new coilovers:
1. u need to take the calliper off 1st ( red circled ones)
2. take the center lock nut out in the center of the hub, should have a split pin in it 2.
3. pull off the rotor and hub
4. now u should see the 4 bolts in the 1st picture they will remove the calliper bracket and backing plate.
now you should have a bare strut like your 1st pic.
to re assemble onto you new coilover struts just do the reverse ov what u did to pull them off..
you only need some sockets with and extension bar.
and don't go balistic on doing the center hub bolt up...
just tighten it up a little then back it off and don't forget the split pin!!!!!
hope this helps dude
