Results 1 to 5 of 5
Thread: t18 front suspension fit ae86?
    Jul 2010
    Carlo
    Kilburn
    sorry was going to edit old post but was locked???
    basically i ned to know if t18 struts and suspension will bolt into my ae86
    thanks
    Rob
    Moorabbin
    sure will...but you wouldn't bother, use your ae86 stuff
    t18 is very similar but save it for ke70s!
    good luck!
    i have ae86 struts re other thread
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Series 1 T18 wont work as the strut tops have a smaller pattern although you should be able to swap strut tops. But series 2 ones will.
    Jul 2010
    Carlo
    Kilburn
    well i jsut need to use them for a day to get my blue slip cause the struts i have on my car atm for some weird reason have stub axles that are to thick for standered front ae86 brakes to fit over. atm it has supra front brakes and i need standered ones for blue slip...
    will the whole t18 front suspension setup bolt in or only the struts. i have some standered ae86 front suspension n shocks i could use..
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    whole setup will bolt in just use your ae86 strut tops
  1. Replies: 1
    Last Post: 11th March 2012, 09:08 PM
  2. ae86 front suspension/brake bits to fit 86 coilovers to ke
    By 70rolla in forum Cars or Parts Wanted
    Last Post: 28th March 2011, 05:54 PM
  3. Do AE86 seatrails fit into a Toyota T18?
    By TrdHowie in forum Technical - Questions
    Last Post: 6th March 2011, 01:35 PM
  4. t18 chrome for the front lights may fit ke too
    By tuff te-72 in forum Car Parts For Sale
    Last Post: 6th July 2010, 07:11 PM
  5. T18 axles fit into ae86 Zenki housing? If so, how?
    By Patric in forum Technical - Questions
    Last Post: 26th August 2008, 06:10 PM
