get your guns out?
found torques for my 16v, the conrod nuts says..
Stage 1: 39nm/29ft lb
Stage 2: +90 degrees
so i torqued the conrod nuts down to 39nm/29ft lb then set out to do the +90 degrees...moved bout 5 degrees and that was as tight as it would go..?
cheers chuckY
Get a half inch drive socket and breaker bar. 39Nm to start is not that tight, you must be too light on the wrench to get the additional 90deg.
I hope you got the torque settings from a reputable source.
yeah that dosen't sound right. is the torque wrench ok?? should be able to tighten it to 80nm+
did you oil the bolt/stud/washer/whatever?
The Toyota manual says 49Nm and the Autodata book says 45-50Nm for conrod bolts
Cool. Get onto it then!
Oil MUST be on the thread and under the head of the bolt.
What model rods are they? I should be able to find out from the ACL book by tonight some time the proper torque.
Just get arp Bolts, I know they are 47 ft/lbs, and I'll resize 'em to suit.
Deal?
