a little off topic here, but I read your 20V cooling guide sam, and you ground down the little blades on the water pump? Well it turns out that brand new 20V water pumps from endurotec already have shorter blades for some reason and it bolts up to a 4ac backing plate no probs! :o![]()
anyway, back on topic, wouldn't it be a little crowded in the engine bay with all the extra water lines and water pump etc. and wouldn't also the small amount of power you might have gained by having cooler water around the intake ports be counteracted by the extra power the altenator had to make to drive the water pump also not to mention having more heated parts in the engine bay thereby increasing engine bay temps therefore losing hp and lastly the extra weight of this whole seperate cooling system wouldn't exactly work to your advantage.
my 2c
