Results 1 to 9 of 9
Thread: How to remove power steering arms from car?
    Senior Member patience's Avatar
    Iain
    Alderley
    Hi Everyone
    I have taken my front suspension assembly off and was wondering what was the best way to remove my power steering arms. They are stuck on the bolts pretty tight. Everything is off the car. I don't want to lay into them with a hammer incase I bend them or something.
    I remember seeing someone make a thread about this very question and searched for it but could not find.
    Any help would be great.
    Iain
    Oldschool Member
    Mar 2008
    undo the ball joint bolt and then use a balljoint seperator
    Veteran anastasios's Avatar
    Taz
    Earlwood
    hammer all the way, they wont bend
    Jun 2005
    hit the side of them with a decent weight hammer.
    will pop off after a couple of hard hits
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (Simon-AE86 @ Jul 10 2008, 09:54 PM) </div>+1
    The best method, smack em side on bloody hard a few times
    Jun 2005
    further more, leave the crown nut on, but unthread it almost all the way so the nut is at the top of the thread, so that if you miss the steer arm, you don't damage the thread on the ball joint.
    Iain
    Alderley
    Fantastic
    Thanks a bunch guys
    Coolangatta
    if you've got a pulley puller it will do the trick very easily + no potential for damaged threads!
    Oldschool Member
    Mar 2008
    add some penetrating oil long time before
  1. power steering arms.
    By 1jz jakey in forum Technical - Questions
    Last Post: 19th February 2010, 09:56 AM
  2. 86 manual steering rack & power steering arms
    By crazy nanna in forum Cars or Parts Wanted
    Last Post: 22nd November 2009, 10:27 PM
  3. power steering arms
    By Hokey in forum Technical - Questions
    Last Post: 30th April 2009, 06:27 PM
  4. Power Steering arms V's Standard NA Arms
    By RyGuy86 in forum Technical - Questions
    Last Post: 8th January 2008, 01:32 PM
