Results 1 to 4 of 4
Thread: Borg warner Q.
    Senior Member Ksevn-T's Avatar
    Hey guys,
    Got given a borgie, which i stripped from it the welded center, pinion and bearings. I then pulled apart my existing diff and tried to install the bearings, pinion and center. I then ran into a problem once i got all the bits in where i could turn the pinion with my hand but the center would get tighter and tighter as it meshed through a tight spot for some reason. I can't seem to find the problem, as the diff i was given ran perfectly. When diff centers get welded do they warp? Can anyone help out?
    Much appreciated,
    Alex
    数独のガレージ "Sudoku Garage" <3<3<3
    Sep 2006
    I don't know the answer to your question. But how did yo setup the crownwheel and pinion?
    What you should have done, assuming your gearset was fine and you jut wanted to fit a weldy. You should have not touched your pinion and just fitted your crownwheel to the welded carrier and then slot that in. heaps easier.
    Oldschool Member
    Jun 2008
    Take it to a diff shop and get it set up properly. Shouldn't cost you too much and it'll pay itself off with all the noise / trouble free driving.
    Removed the pinion ant replaced it with another because it was a whining bitch!
    Ended up putting the un-welded center back in because i just couldn't get the welded center to turn. Ggrrrr!
  1. KE70 Borg Warner Diff
    By Jacobxxx in forum Cars or Parts Wanted
    Last Post: 22nd September 2011, 02:08 PM
  2. borg warner axel
    By sprint86 in forum Cars or Parts Wanted
    Last Post: 14th February 2010, 12:38 PM
  3. KE70 Borg Warner Diff
    By sundee in forum Car Parts For Sale
    Last Post: 17th August 2009, 06:48 PM
  4. Borg Warner Diff for KE70
    By 1JZ Z20 in forum Cars or Parts Wanted
    Last Post: 6th July 2007, 12:41 AM
