Results 1 to 3 of 3
Thread: Manual steering conversion problem
    Nov 2007
    I've taken out my power steering set up and replaced it with a manual one.
    Everything fine apart from one bit - connecting the steering rack to the steering column.
    The shaft from the steering wheel is about 7-8cm too short to reach the rack :blink: Reason is the power steering joint is quite a bit higher as it sits on a resorvoir for the power steering fluid, so is actually closer to the steering column.
    I guess they are different parts, and assuming I'm going to struggle to find the manual steering bar bit, what else can I do to fix it together? Surely someone else must have come across this problem :confused:
    Thanks :2thumbs:
    Sep 2010
    Dave
    Southern
    you can use a MK3 supra intermediate shaft on the power steering column.
    marvin
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    You will also need a non-power steering yoke because the power steering one wont tighten up over the manual rack.
    These are all the same over a massive list of cars. Including KE70 and AE71's, SV21's, AL25's etc etc
  1. Replies: 2
    Last Post: 3rd September 2012, 11:04 AM
  2. Replies: 1
    Last Post: 3rd July 2012, 05:33 PM
  3. 1986 (or simalar) corona manual wreck or manual conversion parts
    By batman.182 in forum Cars or Parts Wanted
    Last Post: 7th July 2011, 09:16 PM
  4. 86 manual steering rack & power steering arms
    By crazy nanna in forum Cars or Parts Wanted
    Last Post: 22nd November 2009, 10:27 PM
  5. WTB:Manual Steering rack & everything for ps to manual
    By sqaure in forum Cars or Parts Wanted
    Last Post: 15th May 2008, 09:39 AM
