Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 10 of 61
Thread: Welded Diff
    Jan 2007
    i am considering welding my diff as i can not afford a 2way diff (as they are more than my car). I have an ae71 with many suspension mods and my car is used as a daily. I just want to get some opinions. Is it still ok to drive as a daily? (not too annoying). How have your axles and rear trailing arm bushings holding up? Where in Adelaide do you recommend getting it welded?
    Any other feedback would be greatly appreciated.
    people in shopping center carparks don't like you and you go through tyres really fast
    also high speed corners can feel a bit dodgy
    Jonathan
    If you go to the racetrack sometimes, extra tyre wear on the street will not be noticeable. High speed corners are fine. With low speed corners you will notice a little bit of initial understeer.
    On a Silvia, I have had to replace a snapped lower control arm after use with a locked diff. On a Corolla, the car is much lighter and you don't get many problems. You can expect to snap an axle after 6 months.
    Veteran DRFTPG's Avatar
    ADAM
    i drive with a locker daily and its fine, easy to put up with. just get some funny looks from people lol. and take it real easy in the wet if theres traffic around
    Nathan
    Lilydale
    mines been locked for a couple o months now, by far the best bang for ure buck mod! can be a tad interesting when parking, and don't run really wide tread on the back.(as if you were going too anyway =P )
    Jan 2007
    Does a locker put alot of strain on the gearbox and driveline? Would it be a good idea to replace the upper and lower trailing arm bushings with nolathane items?. Cheers for your comments. Keep them coming.
    Would it be ok to have 195/50/15's on the back with the locker.
    Sep 2006
    All my corollas have had lockers, never had a problem.
    Also i have locked centers for $30 Changeover in Adelaide
    ADAM
    yeh that tyre size will be fine, don't even worry about the bushes till they go, just lock her up and start driving..you will never go back!!!
    May 2008
    <div class='quotetop'>QUOTE (SON57A @ Jul 15 2008, 03:40 PM) </div>true
    my favourite was going into one of them car parks floors that squeak when you turn, that was so funny with a locker
    I've got 185's on the rear and mine don't squeal, its sweet as.
  1. Need a diff welded!
    By x744 in forum Sydney & NSW Events and Discussion
    Last Post: 18th February 2012, 08:57 PM
  2. ST141 welded diff ??
    By Jarona in forum Technical - Questions
    Last Post: 12th September 2011, 09:59 PM
  3. welded s -series diff
    By #109 in forum General Topics (No Technical Questions)
    Last Post: 17th June 2008, 10:31 AM
  4. welded diff for sale
    By 13rendan_88 in forum Car Parts For Sale
    Last Post: 11th February 2008, 10:29 PM
