Results 1 to 8 of 8
Thread: 4A-C PROBLEM
    Member ronin_SPL's Avatar
    Apr 2010
    chaiyapol
    bangkok
    Bangkok
    Thailand
    My 4A-C is missing I'm not sure what the problem is because its got good compression in all cylinders, new leads, new condenser, new dizzy cap, new points gapped correctly and new spark plugs could it be the coil or distributor? its annoying cos in traffic when you try to pull out onto a road it has no low end power at all it only starts to get power at about 3500rpm. thanks :greenbounce:
    Andrew
    <div class='quotetop'>QUOTE (4a-cnt @ Jul 18 2008, 10:25 PM) </div>fixed!!!
    Apr 2010
    chaiyapol
    bangkok
    Bangkok
    Thailand
    I wish.
    Oldschool Member
    Jan 2006
    big cannon on it???
    Dave
    get some carburetta and throttle body cleaner....and go absolutely nuts
    - Blaise Pascal
    Veteran Konakid's Avatar
    Henry
    Eastern
    Stock carby? Or is this the built one with the weber?
    don't forget to set the timeing
    Apr 2010
    chaiyapol
    bangkok
    Bangkok
    Thailand
    Its got 286 cam and a weber but the weber is rebuilt so it shouldn't be the problem also the timing is fine i might have to take it to a mechanic. <_<
  1. t50 4A bell -> t50 2T gbox seal problem
    By PULSE in forum Technical - Questions
    Last Post: 15th June 2008, 12:29 PM
  2. 4a problem, maybe Broken/damaged valves???????
    By Maxhag in forum Technical - Questions
    Last Post: 1st January 2008, 07:57 PM
  3. Unifilter Air filers, 4A-C Carb on 4A-GE manifold
    By asher in forum Car Parts For Sale
    Last Post: 15th June 2007, 08:16 AM
