Results 1 to 6 of 6
Thread: 4AGE ECU question
    Oct 2006
    OK the ECU in my sprinter has died and I need to replace it. What I need to know is were there different models of the stock ECU released in the JDM AE86. If so are they interchangable e.g. same pin configuration, same engine.
    I'm a bit lost here, and any help/information would be much appreciated.
    I apologise if the answer to this question is obvious but I have searched and haven't found what I needed.
    Oldschool Member
    Mar 2008
    i believe that there was only 1 JDM ECU for the AE86....
    no matter what the model
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    <div class='quotetop'>QUOTE (ae86_Guy @ Jul 19 2008, 03:57 PM) </div>There are 2 different JDM AE86 ECU's both are interchangeable, just one came in the zenki, the other in the kouki. The kouki one is in fact the designated replacement part for the zenki one.
    Internally I don't know if there is any difference but there are 2 different part numbers.
    There are plenty of other ECU's that will plug in though, just about any bigport ECU will work but any of the Australian ones will not allow you to develop as much power.
    Oct 2006
    Thanks for the information, thats what i needed to know.
    Anthony
    zenki rev cut = 7600, kouki rev cut = 7300
    Lawrence
    Wollongong
    <div class='quotetop'>QUOTE (Anthony @ Jul 21 2008, 11:08 AM) </div>That's interesting, I wonder why the lowered the rev limit.
  1. ECU question
    By aus_86 in forum Technical - Questions
    Last Post: 22nd March 2011, 06:03 PM
  2. Replies: 15
    Last Post: 22nd December 2009, 05:48 AM
  3. Razorback ECU and Diff question
    By ROSCO in forum Technical - Questions
    Last Post: 22nd July 2007, 07:37 PM
  4. Silvertop ECU question
    By DRF786 in forum Technical - Questions
    Last Post: 27th October 2006, 02:47 PM
