No you can't use a T-18 one, you'll need either an AE71 one or an AE86 variety. Either will bolt in.
When putting a 4AGE in a KE70, I believe you can use the crossmember and the engine mounts out of an AE71 to do it, is this correct?
Can the crossmember and mounts from a T-18 also be used in a KE for a 4AGE?
Basically I have a KE70 and want to put a 4AGE in it, what crossmembers and mounts will I need and can I get them out of a T-18 (as I also have one of these)?
Any help is much appreciated.
engine AND gearbox crossmembers.
why do people always forget the gearbox one? haha
AE71 - 4A & T50
AE86 - 4A & T50
T18 - 3T & T50
KE70 - 4K & K40/K50
You need AE71 or AE86 crossmembers, T18 is a 3T-C motor, mounts are totally different. Pretty sure that you can't use the Gearbox crossmember from a T18 either.
yep u will need crossmembers from an ae71
i have both engine crossmember and gearbox crossmember from an ae71
50 bux each, plus postage if you want them
no1 down here seams to want em lol
<div class='quotetop'>QUOTE (todd @ Jul 20 2008, 06:22 PM) </div>Yeah sorry, my response was somewhat vague. I had only just woken up, come to think of it my alarm was set for 12pm so that's only 5 minutes after I got up. :whistling:
starni-boy above has given the good info
I have the engine corss member you will need in melbourne. It is form an AE86 and has lower control arms, castor rods and mounts attached and maybe some more stuff. Ready for you to drop your cross member out and put this one in.
PM me if you need it.
Thanks guys, I now know what I need.
Rallystanza I PMed you and if that falls thorugh ill contact you grape_moosha.
Thanks again.
