Hi,
I got my w5x gearbox bolted up to my engine, and now need to mount bolt it to the chassis.
How do I go about doing this?
There is plenty of threads about the bellhousing and adaptors to bolt to engine, but nothing about to the car. Does anyone have measurements of the plate needed to be made to bolt it up?
Thanks
You will have to measure it up yourself and make up a braket out of steel angle or box tubing. Best the re-use the rubber nount in making your new mount.
Most cars will have different measurements. You will have to do your own, or get someone who can do it for you as you will most likely need to weld.
