I have here a small port loom and ECU, I did have it for sale a while back but the buyer dropped out.
Anyway, its currently in FWD form straight out of an AE92 SX. It comes with a coil, ignitor, intake temp sensor, map sensor, fusebox and the ECU.
I have tested the ECU recently and it worked fine, and when I tested the loom a month or two ago it also worked fine.
I just finished my own small port wiring for my AE71 and I've done it to factory looking standard integrating the loom into the original fuse box and doing A LOT of extensions to sections so that everything goes in neatly. Every join was soldered and heatshrinked, and I probably did somewhere between 100-150 joins all up and also kept the complete original wiring color scheme on all the extended sections. Because its so neat it took me an insanely long time to complete, maybe 24 hours odd actual labor time. I honestly don't want to do it again because it just took so long but I need money so I'll do it for an extra $250.
If people are interested, I'll put up pics of my engine bay.
Otherwise, here is the photo of the loom which I took a while ago:
That isn't in fact the correct coil & igniter pictured, but it will be supplied with the correct ones.
Complete loom and ECU: $250
Entire package including complete modification of loom: $500
Any other cars needing wiring pm me and I may be able to help with a solution.
Items located in Wollongong NSW
