Results 1 to 6 of 6
Thread: ke30 lca's in ke70 will they fit?
    Dec 2006
    i have ke30 lca's whick are a bit longer but i want to know will they fit in a ke70??
    Jonathan
    Yes, they should be a good fit.
    KE30 arms are the same as RA23 and RA40 and XT130 from memory. They are a bit longer than KE70/AE86 so perfect for a bit of extra track and camber.
    if they are the same item as ke55? LCA's then yes
    i've done this b4 to a ke and they give 1.8 - 2 degrees camber approx
    add some new ball joints and it is a good noticable handling mod
    don't think they give that much, but yeah, definitly a good mod,
    do it, when you do it will put your wheel alignment way out, so do a home alignment before your drop it down, then first thing take it to a place to get it done proper
    Stefan
    Parkinson
    <div class='quotetop'>QUOTE (grape_moosha @ Jul 27 2008, 08:07 AM) </div>
    yeah it gives about 1.8 deg camber
    i was with jarryd when he got his wheel alignment done thats what the sheet said!
    yeah ke30 is same as ke55 xt130 etc
    so 10mm track per side!
    with a good wheel alignment ull be fine!
    ra40 LCA are also the same
  1. xt130,ke30,ke55,ra40 lca for my ke
    By NAH-JKS in forum Cars or Parts Wanted
    Last Post: 15th April 2012, 02:53 PM
  2. KE70 - XT130 Struts and LCA's - Does KE70 Sway bar fit
    By Futo_gt86 in forum Technical - Questions
    Last Post: 31st July 2011, 04:25 PM
  3. will rose jointed LCA's fit in E7s with stock struts?
    By mtgg85 in forum Technical - Questions
    Last Post: 14th July 2008, 05:15 PM
  4. will xt130 LCA's fit in a ke70 with the stock struts??
    Last Post: 7th July 2008, 12:49 AM
  5. do xt130 lca's fit ke70?
    By dori king in forum General Topics (No Technical Questions)
    Last Post: 21st October 2007, 10:41 PM
