Results 1 to 6 of 6
Thread: hilux diff centre
    Jul 2008
    hi guys.
    i a in the market for a diff for my ae86. i have been looking around at whats on the market, and have alot in the way of hilux rear ends.
    i am wondering... does anyone know of any after market 2 way centers for this type of diff???? any help on this would be greatly appreciated....
    cheers.
    Ok
    Seamus
    Milton
    <div class='quotetop'>QUOTE (johnk84 @ Jul 26 2008, 05:08 PM) </div>OS Giken, ATS, KAZZ, TRD, etc ... all make G-series LSD's that will fit into your housing
    BUT there is a catch, while they *fit*, you need to do two things
    1) Make a spacer plate that's 3mm thick, to space the crown wheel from the centre .. not hard, just a big ring with some holes drilled in it
    2) Buy different bearings to suit (any diff shop should be able to work this out, if not, they shouldn't be touching your diff)
    If you want a less agressive, straight-bolt-in option, there are some TrueTrac LSD's etc available from the states, aren't too expensive either, just not quite the same as your clutch-based alternatives
    ^ Clicky clicky!
    Jul 2008
    thats funny, cause the diff shop that i spoke to said that kazz does not make a mech center 2 way.
    who cane get these centres????
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    by what ive been told there are no direct fit 2 way lsd's to fit the g series center, however , you can get a center out of another model and make it fit the way 70XIN said.
    The only straight fit centers ive found are lockers and a atb diff from quaife
    Jonathan
    You have to be a bit carefull using the term "2-way" to describe a LSD. It is only ment to be a general description of how a LSD maybe designed to lock up both under acceleration and deceleration. So technicaly, the factory Toyota HiLux LSD is a "2way" as it does this, although it is of a slightly different design to a TRD clutch pack diff or something like that.
    there are detroit lockers, lockright auto lockers & more ,even arb air lockers
    the auto lockers are cheap in the states from 4wd off road type shops
  1. G series Hilux diff to suit KE70 - LSD centre
    By GOODY in forum Car Parts For Sale
    Last Post: 5th June 2013, 09:49 PM
  2. G series hilux diff centre non LSD
    By reecegze in forum Cars or Parts Wanted
    Last Post: 21st April 2012, 03:05 PM
  3. Replies: 2
    Last Post: 30th September 2011, 04:35 PM
  4. Open centre zenki type T Diff centre + front snout
    By LordNafe in forum Car Parts For Sale
    Last Post: 21st May 2010, 12:58 PM
  5. Hilux diff centre
    By GOODY in forum Cars or Parts Wanted
    Last Post: 21st June 2009, 02:34 PM
