Results 1 to 7 of 7
Thread: Help with fuel pump wiring
    Probably sounds like a stupid question but I'm not the best with wiring. Can anyone tell me how I need to wire my fuel pump/lift pump etc. so that when the ignition turns on the pump comes on for a few seconds then stops until I start the car? Instead of the pumps staying on even when the cars not started..
    Senior Member h1_roll4's Avatar
    Josh
    C raigie
    I'm prity sure most pumps turn themselves off when there not needed. so you just need to connect it to a + current.
    PEWPEW
    May 2008
    you got to be special to have that, I just wiring my tigger from the ecu and mine does turn on then off
    Nathan
    Lilydale
    i'd use 2 standard relays, switching either one will put positive to both ure pumps.
    one relay turns on when u crank the car (just grab + start wire to switch this relay)
    The other turns on when the ecu sees that the car has started, and outputs an earth (ive forgotten which ecu pin it is but i could check my smallport for u)
    This way your pumps are only ever on when the engine is running, or when ure cranking, this is how the standard fuel pump relay on a FWD 4AGE works.
    Ive done this on 3 4age convo's now and it works a treat!
    fuel pumps or at least pressure pumps I've worked with are always on when they have power.
    you have an SR20 right?
    pin 85 and pin 30 to some sort of power be it battery or ignition
    pin 86 to the black pink wire off the ecu
    pin 87 is the fuel pump power wire
    If you have two pumps just do the above but with a relay for each pump.
    Done.
    Reeece
    Casula
    wire from battery to a relay...splice into your COR on your existing pump and use this as a switch to go to full 12v power from the battery whilst car is running. Easy
    Thanks heaps everyone for the help, got it working good today
  1. EFI fuel pump wiring, help please
    By ian6375 in forum Technical - Questions
    Last Post: 17th August 2013, 04:23 PM
  2. Intank fuel pump wiring
    By Matt in forum Technical - Questions
    Last Post: 31st January 2012, 11:07 PM
  3. Fuel pump wiring
    By ozyvr4 in forum Technical - Questions
    Last Post: 18th May 2011, 08:53 AM
  4. Fuel pump wiring
    By Sparkle86 in forum Technical - Questions
    Last Post: 3rd September 2007, 08:25 AM
  5. fuel pump wiring
    By driftster in forum Technical - Questions
    Last Post: 19th February 2007, 11:58 AM
