Results 1 to 10 of 11
Thread: MY CAR WONT START
    Mar 2008
    I changed the gap in the points to 0.5mm what ke70dave told me to change it to and now my car wont start at all. I looked at the spark plugs to see if there was any spark and there didnt seem to be. Can anyone help me as i need it for school. Thanks Troy
    Senior Member orido's Avatar
    Orido
    outtheback
    why did you change the gap ? no spark sorry to state the obvious.
    Jonathan
    Turn ignition on, check you have 12volts at the coil with a multimeter. Check all high tension leads, resistance and how they are fitted. Rotor turns clockwise. Firing order, 1-3-4-2.
    Put piston one at TDC. Check rotor faces No.1 plug lead etc...
    Put crank at 10 degrees, turn ignition on, take dizzy cap off, turn dizzy till you see the pionts arc etc...
    Dave
    <div class='quotetop'>QUOTE (Troy09 @ Jul 31 2008, 06:19 PM) </div>uh-oh, what have i done :confused:
    i had this problem a few times
    points seem to do random crap.
    a few times ive changed mine, and it hasnt started or sparked, so ive taken them out, and done it again, and its been fine
    how did you adjust them, did you make sure you adjusted them when the cam inside the dizzy pushing them appart?
    just whatever you do...don't put your screwdriver on the points with ignition on..get a nasty surprise and you can't feel your arm for about 30mins...
    also make sure you didn't put any oil on the contacts of the points, that can bugger things up to.
    - Blaise Pascal
    Mar 2008
    Post
    <div class='quotetop'>QUOTE (orido @ Jul 31 2008, 07:22 PM) </div>Asked for help not stupid comments. And tomorrow I'm just going to replace the plugs points and leads and go from there. Thanks for the help guys
    daf
    qld
    springfield lakes
    Aust
    Make sure that the points are clean. If you were adjusting them, you may have left a film of dirt, grease etc on them. Give them a clean and see how it goes. I had a similar problem once when I replaced my points. Put brand newies in and it had no spark. Tried everything and it still wouldn't spark. Eventually, cleaned the points and, what do you know, had a spark again. Might be worth a shot. :confused:
    Mar 2008
    <div class='quotetop'>QUOTE (blinded_ @ Jul 31 2008, 07:31 PM) </div>
    Ill go give them a quick sand now and hopefully this works thanks mate.
    daf
    qld
    springfield lakes
    Aust
    Sand and THEN give it a quick wipe with a rag to remove any sandpaper/metal residue. :2thumbs:
    Mar 2008
    Well that didnt work. Ill just replace all the points plugs and leads i spose. Cars can be a c**t really.
    Jonathan
    replace condensor also if you are really replacing everything.
    But replacing everything is not really needed if you actualy know how to check and adjust things.
  1. Car wont start
    By MeZ Prod in forum Technical - Questions
    Last Post: 15th February 2012, 11:50 AM
  2. car wont start
    By james86 in forum Technical - Questions
    Last Post: 6th September 2008, 02:54 AM
  3. Car wont start
    By Ko Ko in forum Technical - Questions
    Last Post: 18th April 2008, 08:36 PM
  4. car wont start
    By The Enthusiast in forum Technical - Questions
    Last Post: 21st August 2007, 12:05 AM
  5. Car wont start
    By 70XIN in forum Technical - Questions
    Last Post: 30th January 2007, 11:48 AM
