Results 1 to 8 of 8
Thread: HELP!! AE86 t50 and crossmember into AE71
    Scott
    Gympie
    Hi Guys,
    Just need a quick hand. I was pretty confident that my Ae86 t50 gearbox and crossmember would bolt into my AE71, But on trying to fit it, Its too narrow, and the bolt holes don't line up. What gearbox crossmember do I need? AE71 t50 or can I use one off the KE70 manual box???
    Cheers in advance!
    AE71 T-50 X-member.
    Ferny Grove
    used AE86 item a few times with no hassle, you trying the front or rear bolt holes? KE70 chassis accepts the front section of the x member and has no provision for the rear ones.
    AE71 item was in my 86 so it shows the bolt hole spacing is the same
    was yours originally auto? EDIT: forgot my white one was auto first and it took an 86 x member.
    Scott
    Gympie
    Not sure If it was originally auto, But I know it had 5 speed in it. I could get the drivers side front bolt in, but thats about it, The 86 crossmember seemed to be too narrow for the 71 tunnel. Wierd. Ill have another crack tomorrow.
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    this might sound stupid but do u have it backwards?
    Veteran biggo's Avatar
    Nick
    Noosa
    ae71's have a wider tunnel.
    don't ask me why. So ae71 xmemeber is the go.
    Scott
    Gympie
    ok, so one of my mates has a KE and he got the T50 and member out of this shit box lol, Will my 86 crossmember fit in his KE? if not, anyone got a 71 member they want to part with? locally preferably, wanna get this motor in by the end of the weekend.. lookin at you biggo lol
    ive got an ae71 t50 crossmember
    if you want it, $50 plus postage,
