Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: strut brace
    Senior Member dunga70's Avatar
    Jay
    Shire
    hey i recived at cusco strut brace today its ment for 86. it is the non adjustable type. it is to go on my e7 i did a rough line up while still in the packageing but the bracde appears too short so my question is will this brace fit or do i need to swap to an adjustable one??
    thanks for the help.
    olympic gold keto
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    why don't u just try and fit it?
    i use a jjr ae86 non adjustable in my e7 and it works fine
    Ferny Grove
    towers are slightly further apart in a 70 than an 86, you will need an adjustable brace. i had the exact same problem with what sounds to be the exact same cusco brace
    is this the cusco brace that looks like all the cheapo knock off braces just lacks the slotted eyes in the brace mounts?
    Senior Member Ksevn-T's Avatar
    I got a strut brace that was for an AE86 or Ke70. The holes were ovaled so that the main bar could move to fit ither strut tower. Apart from that the towers have the same bolt pattern.
    数独のガレージ "Sudoku Garage" <3<3<3
    Jay
    Shire
    here are two pics.. the one i got is the top one in both pics.. pretty sure i need the bottom one.. reason i did not remove from packet in case i have to send it back. i think ive seen a cusco brace in a 70 before but I'm pretty sure this is different.. ??
    olympic gold keto
    They fit. As seen on Popes car.
    Jay
    Shire
    k for everyone else out there it fits. just had a call from dave at ajps. he said loosen the 2 bolts at each end and it will fit snug as a bug then do the bolts up again.. too easy. thanks everyone.
    , jay
    olympic gold keto
    IK havet the same one as popes. Never any trouble fitting.
    Jay
    Shire
    anyne else here fitted that type of cusco brace.. i can't seem to make it fit.. how did u do it..? cheers
    olympic gold keto
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    I've got a JIC one the same as that. Had to pull a bit on it to make it fit, but it got there.
  1. strut brace
    By ke2483 in forum Cars or Parts Wanted
    Last Post: 12th October 2012, 12:07 PM
  2. e86 rear strut brace and Harness brace
    By FATPANDA in forum Car Parts For Sale
    Last Post: 18th April 2011, 08:23 PM
  3. strut brace
    By johl in forum Offtopic Discussions
    Last Post: 26th May 2008, 12:42 AM
  4. Strut Brace
    By stouty in forum Cars or Parts Wanted
    Last Post: 6th June 2007, 12:42 PM
  5. strut brace
    By spillman in forum Technical - Questions
    Last Post: 11th November 2006, 10:45 PM
