Is this the correct way to set up a draw through setup.
will be using a cordia turbo tc05. have a td04l but think its abit big.
will be butchering the exhaust manifold up with the flange off the cordia,
and a custom dump pipe.
how much power will be acheivable?
8-10psi sound right?
will just be using the standard carb.
whats the go with water injection? is it needed?
thanks
oops forgot to include dump pipe but ya get the idea
<div class='quotetop'>QUOTE (julzy @ Aug 6 2008, 06:15 PM) </div>SU should be close enough to free, get one off an old datsun zed or british car. For fuel just get a electric pump and run it to the carb with no return, as long as it doesnt fk the pump it will be sweet. I'm guessing you'll want a low pressure pump, but I'm not 100%.
acctually carb will be easy to get, dads mate,
so just a pump off an older efi car? early magna or something,
might just run it with a adj. fuel reg to be safe
<div class='quotetop'>QUOTE (julzy @ Aug 6 2008, 06:40 PM) </div>nah don't need a reg, SU's work on vacuum I think so it will suck more fuel in if there is more vacuum...
