I guess you mean AE92? Yes GZE ecu is fine for running turbo, boost cut is at 1bar (14.7psi).
just wondering if a GZE from an ae82, afm with coil packs can run a turbo on a standard ecu? and if so how high can you run the boost?
cheers.sam
well its afm so i think it only came in the ae82, but cool thanks for the info!!!
no ae82's came out with gze's.
aw11 and early ae92 were afm
the only thing ae82s are good for is their 7rib bigports haha
aw11 had afm and dizzy
i think most ae92's had afm and coil packs.
The 4agze afm ecu has no boost cutout so becareful.. i am running 9-10 psi on my t28 and its on the boarder line of fuel leaning on the ecu..
But other then that 10 psi and the reliability of the stock ecu its FTW comes on boost hard to
<div class='quotetop'>QUOTE (samuek @ Aug 11 2008, 09:08 PM) </div>
