Results 1 to 7 of 7
Thread: wheel bearings kouki vs zenki
    Senior Member ae86=fun's Avatar
    Tobias
    Battery Point
    Thumbs up
    hi ive been told my rear wheel bearings are on the way out so i thought i would ask this dumb question before i go spend money on possibly the wrong bearings..
    is their any difference between the wheel bearing size of a kouki rear end versus a zenki rear end.
    i know that their is an axel size difference but does this effect the wheel bearing size??...
    PS: :confused: i'm a noob..
    Senior Member eightsixboy's Avatar
    Paul
    East
    (edit :whistling:, Zenki drum) axles have smaller bearings than the kouki axles, I'm 99% sure all kouki rear ends are discs, and the bearings are way different, something like 20-30% bigger.
    I would actually like to know the size of the zenki bearings compared to an s-series axle if anyone knows? They might be the same, when i replaced bearings on my axles for my t-series they were the same as a local corolla funnily enough in bursons listing.
    Ru-iki
    Kouki Bearings :blink:
    Tobias
    Battery Point
    Thumbs down
    Ru-iki can you post up the part number for the kouki bearings...
    Jonathan
    There is no difference in wheel bearings between zenki and kouki.
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Thats right Zenki and Kouki Disc Brake rear end Axles run the same Twin ball brg type.
    Easy way to tell is have a look at the rear end near the brake backing plates for the larger dia and width in the Hsg, compared to say the T series T18 which only runs the single row type ball brgs and has a different looking shape near the backing plates.
    Have seen a JDM AE86 Drum rear end with the single ball type brgs but the axle splines were the same as kouki .
    Hope this helps you more than confuses yah.
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Tobias
    Battery Point
    <div class='quotetop'>QUOTE (Jonny Rochester @ Aug 15 2008, 04:23 PM) </div>all i wanted to hear
    now i can go shopping without the worries of spending money on the wrong shit
    cheers guys :2thumbs: :2thumbs:
  1. Jdm Zenki Diff bearings
    By Futal in forum Technical - Questions
    Last Post: 23rd October 2011, 11:12 PM
  2. Zenki rear axle bearings ??????
    By AIROCOBRA in forum Technical - Questions
    Last Post: 17th August 2010, 07:27 PM
  3. zenki and kouki disk diff double row bearings? are they the same
    By hachi_dk in forum Technical - Questions
    Last Post: 12th June 2010, 08:15 PM
  4. Wheel bearings
    By daz in forum Technical - Questions
    Last Post: 17th April 2008, 10:57 PM
  5. for sale. axles suit late kouki diff with bearings
    By ar86 in forum Car Parts For Sale
    Last Post: 25th May 2007, 09:45 AM
