Results 1 to 9 of 9
Thread: tie rod ends...
    Senior Member dunga70's Avatar
    Jay
    Shire
    i have read the got camber thread.. ont think anyone has what i have. got confused by the thread after a while so many xt130, ra40, numbers everywhere.. anyway hoping someone can answer this before i go for wheel alignment tomoro. i have 86 strut in my ke70. when i got it i had sigmas in it with neg3.5 camber. with ra40 tie rod ends i think? so ive now put in xt130 corona arms the ra40 tie rods looked too long so ive put he standard 70 ones in and its very roughtly alighned.. tomoro arvo its goin to get an alighnment. can anyone tell me if the arms are gonn be too short? cause that would be embarrasing lol..
    help would be good. thanks..
    ,jay
    olympic gold keto
    Jun 2005
    you can use the stock tie rod ends, there will be enough thread
    I'm running the same, had a wheel alignment, it was mint. You'll be fine.
    Jay
    Shire
    someone told me that 70 and 71 rods are different? true faulse??
    olympic gold keto
    Jun 2005
    yes its true, but they are the same length, they are just a slightly different design i believe
    Jay
    Shire
    ok thanks lads... ill give it a go tomoro.. can't get worse than how it is.. lol lets just hope it works.. cheers..
    olympic gold keto
    Senior Member Ksevn-T's Avatar
    Can you replace the stock tie rod ends with rose joints with bolts through them?
    数独のガレージ "Sudoku Garage" <3<3<3
    Ferny Grove
    you can but you should really have a tapered insert to suit the tie rod mounting hole of the steering arm. it needs this taper to have a tight interference fit, just running a bolt through the hole will mean the steering arm when in motion (turning) can spin independant of the bolt which will cause it to wear, make noise and eventually snap if not corrected. the other issue is the bolt would have to be the same size of the smallest point on the arm hole which is the top, remember because its tapered the top and bottom of the hole is a different size so in reality the bolt only passes "tight" through a very small section of the tie rod end hole.
    Question answered. All makes sense now. Thanks Gilly
  1. Tie rod ends
    By Bozu in forum Technical - Questions
    Last Post: 3rd May 2011, 11:38 AM
  2. Replies: 0
    Last Post: 5th March 2010, 06:59 PM
  3. WTB front short stroke shocks, tie rods & tie rod ends.
    By Ade_Mc in forum Cars or Parts Wanted
    Last Post: 24th October 2007, 11:58 PM
  4. Tie Rod Ends
    By LeviNafey in forum Technical - Questions
    Last Post: 24th October 2006, 09:38 AM
