Results 1 to 6 of 6
Thread: gbox oil filling from shifter
    Sep 2006
    Thumbs up
    after i took the T50 shifter off
    i found a small hole in the place where the shifter bush goes into. (for lubricant purpose i think)
    is it the only place i can fill the oil through?
    it took so long to get just a little bit of oil in... so i wonder if i can fill through the big hole(housing, if you know what i mean)
    thanks
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    don't put it in the shifter bush hole.
    pour it down the side of the rectangular bit of metal that it sits in.
    it will save alot of time.
    but really u should fill it from underneath with a hand pump through the filler plug.
    and make sure u put the right amount in, i forget how much it is but I'm sure someone will be able to tell u.
    Rob
    Moorabbin
    1.9l
    Sep 2006
    <div class='quotetop'>QUOTE (todd @ Aug 21 2008, 12:50 AM) </div>thanks, the housing i was talking about is the rectangular cave, so it can go through there, right?
    <div class='quotetop'>QUOTE (truenosedan @ Aug 21 2008, 01:09 AM) </div>i thought 1.7l is the max~
    Jan 2007
    yeah just take of the shifter and pour it in there, it doesnt need to go into that little hole takes too long... take of the over flow bolt ( located on the side of the box) and when it comes out of there then its full
    Sep 2006
    thanks guys
  1. T50 gearbox filling question
    By ke_70_blue in forum Technical - Questions
    Last Post: 4th December 2012, 08:42 AM
  2. Flywheel is exposed after bolting gbox up
    By randomskate in forum Technical - Questions
    Last Post: 30th June 2011, 09:33 AM
  3. How to tell if gbox/diff is dying?
    By tc-rolla in forum Technical - Questions
    Last Post: 15th January 2010, 03:04 PM
  4. mmm CREAM FILLING!
    By todd in forum Youtube Chan
    Last Post: 18th December 2009, 11:45 AM
  5. How do you.. filling oil shocks with diff oil
    By enigma in forum Technical - Questions
    Last Post: 10th January 2006, 05:11 AM
