nice fucking car! haha
1 x Ebay Manifold Suit 16v Or 20V (holes have been drilled) $300
with bolted on (flange welded on)
1x WRX MY00 TD04L modified wastegate to suit clocking. $300
Together: $550
NA or FI RWD Smallport 100kw Inlet Manifold (no throttle body) $250
Converted along the runners. Therefore you can use it as a NA manifold with the correct idle up system control and crank case venting.
4age Brand New Distributor Cap. $25
Blank SR20 Inlet Manifold No throttle body $30
T50 Crossmember No Rubber Mount : $50 onhold
4age Universal Thermostat. (just like the ones you would buy from an auto shop) Comes with gasket $15 onhold
Universal Catch Can. Comes with hoses. $50.00 onhold
Random stuff:
Ke30 factory steering wheel $20
4x 10mm slip on wheel spacers. Came of "the" rona. The Old Pac Rona $100
T3/T4 Turbo charger Its huge compared to my td04. $200
Used External Wastegate.
Also forsale:
600x300x76mm FMIC Universal type. Freshly cleaned. Good for 12.6 second minimum quarter miles... $150
Parts in Blacktown NSW. Small items will post.
Contact: pm me or post here.
pm me for phone number.
has the tdo4l got any shaft play in it?
and does it come with oil and cooling lines?
had any trouble with the mainy overheating and cracking heard bad things about them ebay shit.
thanks dori
<div class='quotetop'>QUOTE (dori?? @ Aug 21 2008, 11:01 AM) </div>i have used this ebay manifold for over 3 years and no cracking at all. Just needs a support brace for the turbo (which this one has). I have run it at wakefield, WSID, many hill runs and it was fine.
No shaft play. The only reason why I'm sellling is to upgrade. If i didnt want over 200kws atw i would keep this setup.
It has coolant lines which are a pushon type then use a hose clamp. Oil lines: If the oil line doesnt fit my new turbo i'll be selling that too. Its braided one with a banjo bolt. Drain pipe is there too.
