<div class='quotetop'>QUOTE (Svenny @ Aug 21 2008, 11:18 PM) </div>Sorry I can't see in your picture but i was wondering if you had the alternator for sale at all? and if you do is it fully functional?
hey guys, got a Silvertop 20v complete block and head sitting here i used for the front cover and was gonna use the pistons in a 4ag but found out they don't fit a big port
sooo I'm selling it off head is seperate with block
Head = cams, buckets springs, cam gears exhaust manifold (fwd), rocker cover, centre cover, NO THROTTLE BODYS
NO cam gear front cover
Block = Pistons, Rods, Crank, sump, crank pulley
I dunno what its worth so
head $200
block $ 250
In south brisbane redlands.
Pm here or 0403779887
will trade for 20v parts (aftermarket cam gears, T series rear end, adj suspension, flat or quad front setup)
Pics up: looks exactly like this but minus the front cover and the head is seperated from the block
Drift skills? i thought buying an import was all you needed? well..... im screwed
Banzai parts garage
Action tyres southport
will u sell the rocker cover and crank pulley seperate?
Will you sell the crank separate?
BUMP still forsale guys
complete bottom end still avail and head minus rocker cover. (and throttle bodys)
swap me for parts
Banzai parts garage
give u 300 for the lot...
soldssss
