Results 1 to 10 of 10
Thread: cams in 16v
    mark
    central coast
    hi, I'm thinking of putting some 256 cams in my 4age. just want to know what brand to go for or stay away from. thanks
    Veteran Konakid's Avatar
    Henry
    Eastern
    Any brand, as you can't buy china copy cams!
    Yet....
    Jonathan
    And 256 seams very mild unless its for turbo or stock ECU. Consider something bigger.
    Senior Member eightsixboy's Avatar
    Paul
    East
    I put in 267 duration cams from a local cam place, as long as there new billet items you can't go wrong, you won't be able to have any more lift than about 8mm on standard springs and shim setup.
    The biggest cam you can run is a 272 with the standard ecu, you probably wont notice much difference with 256 duration cams, i would go as big as you can, maybe somewhere around a 270 duration if your planning on keeping the standard ecu and not touch the valve srpings.
    With my 267 duration cams dialed in I noticed a different power curve, more top end and gained 2-3 rwkw. You should also get some adjustable cam gears so you can get the most out of them.
    Henry
    Eastern
    Definately agree with Jonny, there is no point spending the money unless you get something worthwhile which means large enough to warrant new valve springs and ecu.
    Putting in new cams with out cam gears, ecu and tuning to suit or valve springs just seems like a pretty pointless mod to me.
    Ok
    Seamus
    Milton
    In regards to Kona.Kid and .. well anyone:
    I agree with the tuning and ecu
    I do not agree with valve springs and cam gears
    Unless using nitrous, or turbocharged, i'm yet to see many motors use anything than the stock location on the adjustable bad boys. Waste of money if that's the case.
    Valve springs: standard ones are pretty good on the ol' 4A. Unless i was doing significant revs and/or farily wild cams, i think this is poorly spent money
    And i believe that a 256/264/272 are perfect for 99% of 4A's .. most simply don't rev high enough to warrant the need for 288's and, god forbid, 304/312's .. how many of you are going the silly side of 10,000RPM?
    Oh, and lift is good, try to get between 8-8.5mm, anything less than that is just a bit gay really.
    ^ Clicky clicky!
    Paul
    East
    I actually had to get cam gears to dial mine in, they werent timed well in standard position. I had something like 100/100 timing and it would idle like poop and had no real top end. I timed them to something like 112/110 from memory, made a big difference.
    Ok
    Seamus
    Milton
    maybe because they weren't "brand name" jap cams?
    not paying out on the local stuff, i know we can make some great gear, just in this particular instance it's interesting
    ^ Clicky clicky!
    Paul
    East
    <div class='quotetop'>QUOTE (70XIN @ Aug 23 2008, 10:19 AM) </div>Exactly lol, wasnt going to spend upwards of 1k for such small cams.
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Any one used Yaris buckets when they upgraded cams?
  1. QLD where do you buy 16v cams?
    By whips in forum Technical - Questions
    Last Post: 11th December 2012, 08:31 PM
  2. Tighe Cams for 16V
    By Vizz in forum Car Parts For Sale
    Last Post: 7th July 2011, 08:34 PM
  3. 16v HKS Cams $650 Sydney
    By trueno85 in forum Car Parts For Sale
    Last Post: 23rd March 2009, 07:03 PM
  4. 16v HKS cams - valve springs
    By FKN16v in forum Car Parts For Sale
    Last Post: 27th September 2008, 04:31 PM
  5. 16v big cams
    By slippry in forum Technical - Questions
    Last Post: 25th July 2007, 03:50 PM
