man get your car sorted already!!! hahaha. i will come have a look this week if you want. ill call ya
hey guys
my car suddenly lost spark today broke down on a round about anyways i checked and there is no spark coming from the coil and i wanted to see if the coil was broken or the ignitor was broken is there any way to test it? also what would cause it to suddenly lose spark. just before this happend my mechanic fixed my dizzy by switching around the wires which made my car run perfect so i was driving for about 5 mins and then it just stopped and now my car is broken again
I'm sorry yes i was completely wrong... i don't even know why i said it
obviously the ground is only there when the dizzy grounds the wire, to calapse the magnetic field etc.
so yes if you have continuous ground at the negative side of the coil then you have a problem....
i do believe that checking the positive side for 12V is a good start though
sorry again for the miss information, and any misleading that may have been caused.
- Blaise Pascal
<div class='quotetop'>QUOTE (ke70dave @ Aug 25 2008, 07:01 PM) </div>What you said there about ground to the negative side is completely wrong. Obviously you don't know how a coil works so I would suggest you don't feed people the wrong information if you don't know what you are talking about.
That said I have already offered once before but you didn't seem interested in me coming to help sort it out?
Why hesitate when you can accelerate???
Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
<div class='quotetop'>QUOTE (Medicine_Man @ Aug 25 2008, 07:43 PM) </div>i was but i had my mechanic try and fix it first but he's not to good with 4age's so yeah ill send u a pm now
